Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Remove the battery cover by applying pressure and sliding down the silver square on the back of the phone.
Remove the battery by prying under it with your finger or the plastic opening tool.
Remove the four small 3/8" long screws using a 1/16" diameter torx screwdriver.
Use a nylon spudger to carefully remove the two side bars of plastic.
Use a nylon spudger to carefully pry the back casing off.
Remove the bottom casing clip, it will easily unsnap when pulled
Unhook both sides of the white wire from the motherboard using the plastic opening tool from before
At the top of the phone, locate the gloss SATA cable strap connecting the LCD screen to the phone.
Using the prying tool, unattach this cable by levering under the connector
Using the prying tool, lever up the old screen as shown.
There will be two small clips on each side of the motherboard. Using the plastic opening tool unhook each clip one at a time
Once all four clips are unhooked you should be able to pull the motherboard from the casing using your hands.
After you remove the old motherboard, you can then replace it with a new one.
3 outras pessoas executaram este guia.
