Ir para o conteúdo principal
BlackBerry 8820 LCD Screen Replacement
O que você precisa
  1. BlackBerry 8820 LCD Screen Replacement, Outer Casing: passo 1, imagem 1 %32
    • Remove the battery cover by applying pressure and sliding the silver square on the back of the phone downwards.
  2. BlackBerry 8820 LCD Screen Replacement: passo 2, imagem 1 %32 BlackBerry 8820 LCD Screen Replacement: passo 2, imagem 2 %32
    • Remove the battery by prying under it with your finger or a plastic opening tool.
    • Remove the four small 3/8" long screws using a 1/16" diameter torx screwdriver.
  3. BlackBerry 8820 LCD Screen Replacement: passo 3, imagem 1 %32 BlackBerry 8820 LCD Screen Replacement: passo 3, imagem 2 %32
    • Carefully remove the two plastic side bars using a nylon spudger.
  4. BlackBerry 8820 LCD Screen Replacement: passo 4, imagem 1 %32
    • Carefully pry the back casing off with a nylon spudger.
    • There are two small clamps on each edge that need to be unhooked before the casing can come off.
  5. BlackBerry 8820 LCD Screen Replacement: passo 5, imagem 1 %32
    • Pry off the front casing.
    • Be cautious of sensors and other sensitive areas of the newly exposed electronics.
  6. BlackBerry 8820 LCD Screen Replacement, LCD Screen: passo 6, imagem 1 %32
    • After disassembling the outer casing, the phone should be stripped as shown.
  7. BlackBerry 8820 LCD Screen Replacement: passo 7, imagem 1 %32 BlackBerry 8820 LCD Screen Replacement: passo 7, imagem 2 %32
    • At the top of the phone, locate the gloss SATA cable strap connecting the LCD screen to the phone.
    • Using the prying tool, disconnect the SATA cable by levering under the connector.
  8. BlackBerry 8820 LCD Screen Replacement: passo 8, imagem 1 %32 BlackBerry 8820 LCD Screen Replacement: passo 8, imagem 2 %32
    • Using a spudger, pry up the old screen as shown.
    • Be sure that the SATA cable is disconnected prior to attempting this.
  9. BlackBerry 8820 LCD Screen Replacement: passo 9, imagem 1 %32 BlackBerry 8820 LCD Screen Replacement: passo 9, imagem 2 %32
    • Insert the new LCD screen.
    • Attach the cable to the connector located at the top of the phone.
Conclusão
ryan
Membro desde: 04/12/13
44 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 13-64, Johann Spring 2013 Membro de Cal Poly, Team 13-64, Johann Spring 2013
CPSU-JOHANN-S13S13G64
4 Membros
Autoria de 7 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 12
Últimos 30 dias: 56
Ao todo: 934
