Ir para o conteúdo principal
BlackBerry 8820 Keyboard Replacement
O que você precisa
  1. BlackBerry 8820 Keyboard Replacement, Disassembling BlackBerry 8820 Outer Casing: passo 1, imagem 1 %32
    • Remove the battery cover by applying pressure and sliding down the silver square on the back of the phone.
  2. BlackBerry 8820 Keyboard Replacement: passo 2, imagem 1 %32 BlackBerry 8820 Keyboard Replacement: passo 2, imagem 2 %32
    • Remove the battery by prying under it with your finger or the plastic opening tool.
    • Remove the four small 3/8" long screws using a 1/16" diameter torx screwdriver.
  3. BlackBerry 8820 Keyboard Replacement: passo 3, imagem 1 %32 BlackBerry 8820 Keyboard Replacement: passo 3, imagem 2 %32
    • Use a nylon spudger to carefully remove the two side bars of plastic.
  4. BlackBerry 8820 Keyboard Replacement: passo 4, imagem 1 %32
    • Use a nylon spudger to carefully pry the back casing off.
    • There are two small clamps on each edge that need to be unhooked before the casing will come off.
  5. BlackBerry 8820 Keyboard Replacement: passo 5, imagem 1 %32
    • Pry off the front casing.
    • Be aware of sensors and other sensitive areas of the newly exposed electronics.
  6. BlackBerry 8820 Keyboard Replacement, Keyboard: passo 6, imagem 1 %32
    • Slide the keyboard downwards, as shown.
    • The keyboard will detach from the casing with a small amount of pressure.
  7. BlackBerry 8820 Keyboard Replacement: passo 7, imagem 1 %32 BlackBerry 8820 Keyboard Replacement: passo 7, imagem 2 %32
    • Slide the new keyboard into the casing. If done correctly, it should click into place and stay secure.
Conclusão
3 outras pessoas executaram este guia.
ryan
Membro desde: 04/12/13
44 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 13-64, Johann Spring 2013 Membro de Cal Poly, Team 13-64, Johann Spring 2013
CPSU-JOHANN-S13S13G64
Membros da 4
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 8
Duração total: 554
