Ir para o conteúdo principal
BlackBerry 8820 Keyboard Replacement
O que você precisa
  1. BlackBerry 8820 Keyboard Replacement, Outer Casing: passo 1, imagem 1 %32
    • Remove the battery cover by applying pressure and sliding the silver square on the back of the phone downwards.
    Pergunte ao FixBot
    Comentar
  2. BlackBerry 8820 Keyboard Replacement: passo 2, imagem 1 %32 BlackBerry 8820 Keyboard Replacement: passo 2, imagem 2 %32
    • Remove the battery by prying under it with your finger or a plastic opening tool.
    • Remove the four small 3/8" long screws using a 1/16" diameter torx screwdriver.
    Pergunte ao FixBot
    Comentar
  3. BlackBerry 8820 Keyboard Replacement: passo 3, imagem 1 %32 BlackBerry 8820 Keyboard Replacement: passo 3, imagem 2 %32
    • Carefully remove the two plastic side bars using a nylon spudger.
    Pergunte ao FixBot
    Comentar
  4. BlackBerry 8820 Keyboard Replacement: passo 4, imagem 1 %32
    • Carefully pry the back casing off with a nylon spudger.
    • There are two small clamps on each edge that need to be unhooked before the casing can come off.
    Pergunte ao FixBot
    Comentar
  5. BlackBerry 8820 Keyboard Replacement: passo 5, imagem 1 %32
    • Pry off the front casing.
    • Be cautious of sensors and other sensitive areas of the newly exposed electronics.
    Pergunte ao FixBot
    Comentar
  6. BlackBerry 8820 Keyboard Replacement, Keyboard: passo 6, imagem 1 %32
    • Slide the keyboard downwards, as shown.
    • The keyboard will detach from the casing with a small amount of pressure.
    Pergunte ao FixBot
    Comentar
  7. BlackBerry 8820 Keyboard Replacement: passo 7, imagem 1 %32 BlackBerry 8820 Keyboard Replacement: passo 7, imagem 2 %32
    • Slide the new keyboard into the casing. If done correctly, it should click into place and stay secure.
    Pergunte ao FixBot
    Comentar
Conclusão
3 outras pessoas executaram este guia.
ryan
Membro desde: 04/12/13
44 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 13-64, Johann Spring 2013 Membro de Cal Poly, Team 13-64, Johann Spring 2013
CPSU-JOHANN-S13S13G64
4 Membros
Autoria de 7 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 49
Ao todo: 939
