Ir para o conteúdo principal
BlackBerry 8703e Battery Replacement
O que você precisa
  1. BlackBerry 8703e Battery Replacement, Battery: passo 1, imagem 1 %32 BlackBerry 8703e Battery Replacement, Battery: passo 1, imagem 2 %32
    • Position your phone like the first image so that the highlighted button is on your left.
    • Slide the battery cover to the left while pressing the button with one hand and applying pressure on the center of the phone with your other hand.
    • Remove the cover completely and set it aside.
  2. BlackBerry 8703e Battery Replacement: passo 2, imagem 1 %32
    • Position your phone like the image to the left, then locate the rectangular battery in the middle of the phone.
    • Locate the notch on the top right of the battery compartment.
    • Slide your fingernail or the flat end of a Spudger in the notch, then lift upwards on the top of the battery to remove it from the phone.
    • Set the battery aside and out of the way.
Conclusão
Equipe
Cal Poly, Team 11-3, Forte Winter 2010 Membro de Cal Poly, Team 11-3, Forte Winter 2010
CPSU-FORTE-W10S11G3
Membros da 5
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 3,382
