Ir para o conteúdo principal
BlackBerry 8700c Replacing Logic Board Replacement
O que você precisa
  1. BlackBerry 8700c Replacing Logic Board Replacement, Replacing Logic Board: passo 1, imagem 1 %32 BlackBerry 8700c Replacing Logic Board Replacement, Replacing Logic Board: passo 1, imagem 2 %32
    • Remove the back cover by pushing down on the button and sliding the cover towards the bottom of the phone.
    • Set the cover aside. The battery will now be exposed.
  2. BlackBerry 8700c Replacing Logic Board Replacement: passo 2, imagem 1 %32 BlackBerry 8700c Replacing Logic Board Replacement: passo 2, imagem 2 %32
    • Remove the battery by pulling back on the notch on top edge of the battery.
    • Set the battery aside.
  3. BlackBerry 8700c Replacing Logic Board Replacement: passo 3, imagem 1 %32
    • Unscrew and remove all four T6 Torx screws.
  4. BlackBerry 8700c Replacing Logic Board Replacement: passo 4, imagem 1 %32 BlackBerry 8700c Replacing Logic Board Replacement: passo 4, imagem 2 %32
    • Pull the back cover of the phone off and set it aside.
  5. BlackBerry 8700c Replacing Logic Board Replacement: passo 5, imagem 1 %32 BlackBerry 8700c Replacing Logic Board Replacement: passo 5, imagem 2 %32
    • Unscrew and remove all 4 T6 Torx screws.
  6. BlackBerry 8700c Replacing Logic Board Replacement: passo 6, imagem 1 %32 BlackBerry 8700c Replacing Logic Board Replacement: passo 6, imagem 2 %32 BlackBerry 8700c Replacing Logic Board Replacement: passo 6, imagem 3 %32
    • Lift and remove inner back cover and set aside.
    • A small side piece may fall away but is simple to reattach.
    • Remove logic board by gently lifting it off of the front cover of the phone.
    • New logic board can now simply be set in place.
Conclusão
arlebrun
Membro desde: 12/02/09
1 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 18-4, Maness Fall 2009 Membro de Cal Poly, Team 18-4, Maness Fall 2009
CPSU-MANESS-F09S18G4
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 3,244
