Introdução
This Repair guide will walk you through the steps on how to replace a RIM Blackberry 8700c logic board.
Ferramentas
Peças
Não são necessárias peças.
Remove the back cover by pushing down on the button and sliding the cover towards the bottom of the phone.
Set the cover aside. The battery will now be exposed.
Remove the battery by pulling back on the notch on top edge of the battery.
Set the battery aside.
Unscrew and remove all four T6 Torx screws.
Pull the back cover of the phone off and set it aside.
Unscrew and remove all 4 T6 Torx screws.
Lift and remove inner back cover and set aside.
Remove logic board by gently lifting it off of the front cover of the phone.
New logic board can now simply be set in place.
