Ir para o conteúdo principal
BlackBerry 7510 Vibration Motor Replacement
O que você precisa
  1. BlackBerry 7510 Vibration Motor Replacement, Back Face of Phone: passo 1, imagem 1 %32
    • Remove the battery cover and battery before continuing.
    • Remove the six T6 Torx screws on the back of the phone.
    • Make sure to keep the screws somewhere that they will not get lost.
  2. BlackBerry 7510 Vibration Motor Replacement: passo 2, imagem 1 %32
    • Using your finger nail or a spudger, carefully pry up the back cover.
    • Begin in one spot and slowly circle around the device as you pry up all of the back cover.
  3. BlackBerry 7510 Vibration Motor Replacement: passo 3, imagem 1 %32
    • Lift off the back cover.
  4. BlackBerry 7510 Vibration Motor Replacement: passo 4, imagem 1 %32
    • Remove the two T6 screws.
  5. BlackBerry 7510 Vibration Motor Replacement: passo 5, imagem 1 %32 BlackBerry 7510 Vibration Motor Replacement: passo 5, imagem 2 %32
    • Remove the daughterboard.
    • Remove the exposed vibration motor.
  6. BlackBerry 7510 Vibration Motor Replacement, Vibration Motor: passo 6, imagem 1 %32
    • Replace with new vibration motor.
Conclusão
Neil Johnson
Membro desde: 01/24/10
12 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 14-44, Regan Winter 2010 Membro de Cal Poly, Team 14-44, Regan Winter 2010
CPSU-REGAN-W10S14G44
Membros da 4
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 4,562
