Introdução
Use this guide to replace the keypad buttons of your BlackBerry 7290 .
Ferramentas
Peças
Nenhum componente especificado.
Apply pressure to the lock button on the back of the device.
Slide the battery cover down towards the bottom of the device, revealing the battery compartment.
Locate the four screws along the perimeter of the back casing.
Remove the four top screws using a T-6 torx screwdriver.
To remove the phone's internals, start by loosening one side by pulling gently.
2 outras pessoas concluíram este guia.
