Ir para o conteúdo principal
BlackBerry 7280 Keypad Replacement
O que você precisa
  1. BlackBerry 7280 Keypad Replacement, Battery: passo 1, imagem 1 %32 BlackBerry 7280 Keypad Replacement, Battery: passo 1, imagem 2 %32 BlackBerry 7280 Keypad Replacement, Battery: passo 1, imagem 3 %32
    • With your thumb press down on the locking- button on the back of the BlackBerry 7280.
    • Slide the battery cover off the device.
    Pergunte ao FixBot
    Comentar
  2. BlackBerry 7280 Keypad Replacement: passo 2, imagem 1 %32 BlackBerry 7280 Keypad Replacement: passo 2, imagem 2 %32
    • Remove the lithium-ion battery from the back of the device using your index finger.
    Pergunte ao FixBot
    Comentar
  3. BlackBerry 7280 Keypad Replacement, SIM Card: passo 3, imagem 1 %32 BlackBerry 7280 Keypad Replacement, SIM Card: passo 3, imagem 2 %32 BlackBerry 7280 Keypad Replacement, SIM Card: passo 3, imagem 3 %32
    • Hold the device with both hands.
    • Lift the SIM card holder using your thumb and index finger.
    • Remove the SIM card from the device.
    Pergunte ao FixBot
    Comentar
  4. BlackBerry 7280 Keypad Replacement, Back Case: passo 4, imagem 1 %32 BlackBerry 7280 Keypad Replacement, Back Case: passo 4, imagem 2 %32
    • Using a Torx T6 screwdriver, remove all six 1/8 inch screws (marked in red) from the back case. Set screws aside.
    • The SIM card has been removed here to prevent damage to the card. This is recommended, but not not required.
    Pergunte ao FixBot
    Comentar
  5. BlackBerry 7280 Keypad Replacement: passo 5, imagem 1 %32 BlackBerry 7280 Keypad Replacement: passo 5, imagem 2 %32
    • Use the plastic opening tool to pry the back case away from the front case.
    Pergunte ao FixBot
    Comentar
  6. BlackBerry 7280 Keypad Replacement, Front Case: passo 6, imagem 1 %32 BlackBerry 7280 Keypad Replacement, Front Case: passo 6, imagem 2 %32
    • Using a Torx T6 screwdriver, remove the lone 1/8 inch screw that holds the upper metal bracket onto the larger metal bracket. Set aside the screw and the bracket.
    Pergunte ao FixBot
    Comentar
  7. BlackBerry 7280 Keypad Replacement: passo 7, imagem 1 %32 BlackBerry 7280 Keypad Replacement: passo 7, imagem 2 %32
    • Remove the front plastic case from the metal bracket.
    Pergunte ao FixBot
    Comentar
  8. BlackBerry 7280 Keypad Replacement, Keypad: passo 8, imagem 1 %32
    • The keypad sits in the keyboard slots on the front cover. Simply peel the keyboard off and replace.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
Clemson, Team 12-2, Benson Spring 2013 Membro de Clemson, Team 12-2, Benson Spring 2013
CLEM-BENSON-S13S12G2
4 Membros
Autoria de 11 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 23
Ao todo: 446
