Ir para o conteúdo principal
BlackBerry 7280 Inner Keyboard Replacement
O que você precisa
  1. BlackBerry 7280 Inner Keyboard Replacement, Battery: passo 1, imagem 1 %32 BlackBerry 7280 Inner Keyboard Replacement, Battery: passo 1, imagem 2 %32 BlackBerry 7280 Inner Keyboard Replacement, Battery: passo 1, imagem 3 %32
    • With your thumb press down on the locking- button on the back of the BlackBerry 7280.
    • Slide the battery cover off the device.
  2. BlackBerry 7280 Inner Keyboard Replacement: passo 2, imagem 1 %32 BlackBerry 7280 Inner Keyboard Replacement: passo 2, imagem 2 %32
    • Remove the lithium-ion battery from the back of the device using your index finger.
  3. BlackBerry 7280 Inner Keyboard Replacement, SIM Card: passo 3, imagem 1 %32 BlackBerry 7280 Inner Keyboard Replacement, SIM Card: passo 3, imagem 2 %32 BlackBerry 7280 Inner Keyboard Replacement, SIM Card: passo 3, imagem 3 %32
    • Hold the device with both hands.
    • Lift the SIM card holder using your thumb and index finger.
    • Remove the SIM card from the device.
  4. BlackBerry 7280 Inner Keyboard Replacement, Back Case: passo 4, imagem 1 %32 BlackBerry 7280 Inner Keyboard Replacement, Back Case: passo 4, imagem 2 %32
    • Using a Torx T6 screwdriver, remove all six 1/8 inch screws (marked in red) from the back case. Set screws aside.
    • The SIM card has been removed here to prevent damage to the card. This is recommended, but not not required.
  5. BlackBerry 7280 Inner Keyboard Replacement: passo 5, imagem 1 %32 BlackBerry 7280 Inner Keyboard Replacement: passo 5, imagem 2 %32
    • Use the plastic opening tool to pry the back case away from the front case.
  6. BlackBerry 7280 Inner Keyboard Replacement, Front Case: passo 6, imagem 1 %32 BlackBerry 7280 Inner Keyboard Replacement, Front Case: passo 6, imagem 2 %32
    • Using a Torx T6 screwdriver, remove the lone 1/8 inch screw that holds the upper metal bracket onto the larger metal bracket. Set aside the screw and the bracket.
  7. BlackBerry 7280 Inner Keyboard Replacement: passo 7, imagem 1 %32 BlackBerry 7280 Inner Keyboard Replacement: passo 7, imagem 2 %32
    • Remove the front plastic case from the metal bracket.
  8. BlackBerry 7280 Inner Keyboard Replacement, Inner Keyboard: passo 8, imagem 1 %32
    • To remove the inner keyboard, simply peel it off of the logic board as shown.
Conclusão
Equipe
Clemson, Team 12-2, Benson Spring 2013 Membro de Clemson, Team 12-2, Benson Spring 2013
CLEM-BENSON-S13S12G2
Membros da 4
Autoria de 11 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Duração total: 297
