Ir para o conteúdo principal
BlackBerry 7100g Screen Replacement
O que você precisa
  1. BlackBerry 7100g Screen Replacement, Battery: passo 1, imagem 1 %32
    • Turn over your BalckBerry 7100g so that the back cover is facing up.
    • Locate the battery cover release button near the bottom of the back panel.
    Pergunte ao FixBot
    Comentar
  2. BlackBerry 7100g Screen Replacement: passo 2, imagem 1 %32 BlackBerry 7100g Screen Replacement: passo 2, imagem 2 %32 BlackBerry 7100g Screen Replacement: passo 2, imagem 3 %32
    • Push down on the release button with one thumb.
    • Slide the battery cover off with the other thumb.
    Pergunte ao FixBot
    Comentar
  3. BlackBerry 7100g Screen Replacement: passo 3, imagem 1 %32
    • Remove the battery from the battery housing by flipping up the top of the battery.
    Pergunte ao FixBot
    Comentar
  4. BlackBerry 7100g Screen Replacement, Housing: passo 4, imagem 1 %32 BlackBerry 7100g Screen Replacement, Housing: passo 4, imagem 2 %32 BlackBerry 7100g Screen Replacement, Housing: passo 4, imagem 3 %32
    • Locate the silver strip near the top of your BlackBerry.
    • Use a plastic opening tool to pry off the edge of the silver lining.
    • Slide the tool along the length of the silver strip to completely remove it.
    Pergunte ao FixBot
    Comentar
  5. BlackBerry 7100g Screen Replacement: passo 5, imagem 1 %32 BlackBerry 7100g Screen Replacement: passo 5, imagem 2 %32
    • Do not lose the screws. They are quite small and can easily be misplaced.
    • Locate and unscrew the four (4) screws using a T6 screwdriver.
    Pergunte ao FixBot
    Comentar
  6. BlackBerry 7100g Screen Replacement: passo 6, imagem 1 %32 BlackBerry 7100g Screen Replacement: passo 6, imagem 2 %32 BlackBerry 7100g Screen Replacement: passo 6, imagem 3 %32
    • The keypad cover may fall out of the housing when prying the housing apart.
    • Tightly pinch the top of the front and back halves of the housing.
    • Carefully pry the two halves of the housing apart.
    Pergunte ao FixBot
    Comentar
  7. BlackBerry 7100g Screen Replacement: passo 7, imagem 1 %32
    • You can now easily remove the "guts" of the phone from the housing.
    Pergunte ao FixBot
    Comentar
  8. BlackBerry 7100g Screen Replacement, Keypad: passo 8, imagem 1 %32 BlackBerry 7100g Screen Replacement, Keypad: passo 8, imagem 2 %32 BlackBerry 7100g Screen Replacement, Keypad: passo 8, imagem 3 %32
    • Turn the "guts" over so the speaker is facing up.
    • Locate and unscrew the four (4) screws near the bottom of the motherboard, using a T6 screwdriver.
    • Separate the battery housing from the motherboard.
    Pergunte ao FixBot
    Comentar
  9. BlackBerry 7100g Screen Replacement: passo 9, imagem 1 %32
    • Pull the keypad off of the motherboard.
    • It should come off with little effort. If not, there are several tabs that can be released on either side of the keypad.
    Pergunte ao FixBot
    Comentar
  10. BlackBerry 7100g Screen Replacement, Screen: passo 10, imagem 1 %32 BlackBerry 7100g Screen Replacement, Screen: passo 10, imagem 2 %32
    • Locate the ribbon connector below the bottom of the screen.
    • Use a spudger to flip up the connector.
    Pergunte ao FixBot
    Comentar
  11. BlackBerry 7100g Screen Replacement: passo 11, imagem 1 %32 BlackBerry 7100g Screen Replacement: passo 11, imagem 2 %32 BlackBerry 7100g Screen Replacement: passo 11, imagem 3 %32
    • Locate the four (4) white tabs that attach the screen to the motherboard.
    • Carefully detach the tabs from the motherboard.
    • The screen can now be removed from the motherboard.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
Cal Poly, Team 25-87, Amido Spring 2010 Membro de Cal Poly, Team 25-87, Amido Spring 2010
CPSU-AMIDO-S10S25G87
4 Membros
Autoria de 17 guias
1Comentário do guia
just a heads up don't do this with a iPhone it does not work at All!
Jaxson HUTCHINSON - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 43
Ao todo: 2,288
