Ir para o conteúdo principal
Black and Decker WP900 Power Cord Replacement
O que você precisa
  1. Black and Decker WP900 Power Cord Replacement, Power Cord: passo 1, imagem 1 %32
    • Using the plastic tool, detach the handle tab as shown.
    • Make sure the device is unplugged.
  2. Black and Decker WP900 Power Cord Replacement: passo 2, imagem 1 %32
    • Using the Philips #1 screwdriver, unscrew all of the screws. There should be 8-30mm screws to remove.
    • Be sure to keep track of where each screw was placed in the device for later reassembly.
  3. Black and Decker WP900 Power Cord Replacement: passo 3, imagem 1 %32 Black and Decker WP900 Power Cord Replacement: passo 3, imagem 2 %32 Black and Decker WP900 Power Cord Replacement: passo 3, imagem 3 %32
    • Remove the back panel of the external casing, leaving all internal components resting in the front panel.
    • Remove the black handle from the main external casing.
  4. Black and Decker WP900 Power Cord Replacement: passo 4, imagem 1 %32
    • Loosen the power cord and control panel. Using the Phillips #1 screwdriver, remove two 22mm screws.
    • The metal bracket will detach with the two screws.
    • Using the Flathead 3/32" screwdriver, remove two 22mm screws.
  5. Black and Decker WP900 Power Cord Replacement: passo 5, imagem 1 %32 Black and Decker WP900 Power Cord Replacement: passo 5, imagem 2 %32
    • Gently pull the power cord out from the control module.
    • This is the part to be replaced. Remember to insert the black wire into the top port when installing the new cord.
Conclusão
Cameron
Membro desde: 02/15/16
231 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team 8-8, Wilson Spring 2016 Membro de IUPUI, Team 8-8, Wilson Spring 2016
IUPUI-WILSON-S16S8G8
Membros da 4
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 11
Duração total: 282
