Ir para o conteúdo principal
Black and Decker WP900 Exterior Casing Replacement
O que você precisa
  1. Black and Decker WP900 Exterior Casing Replacement, Exterior Casing: passo 1, imagem 1 %32
    • Using the plastic tool, detach the handle tab as shown.
    • Make sure the device is unplugged.
  2. Black and Decker WP900 Exterior Casing Replacement: passo 2, imagem 1 %32
    • Using the Phillips #1 screwdriver, unscrew all of the screws. There should be 8-30mm screws to remove.
    • Be sure to keep track of where each screw was placed in the device for later reassembly.
  3. Black and Decker WP900 Exterior Casing Replacement: passo 3, imagem 1 %32 Black and Decker WP900 Exterior Casing Replacement: passo 3, imagem 2 %32 Black and Decker WP900 Exterior Casing Replacement: passo 3, imagem 3 %32
    • Remove the back panel of the external casing, leaving all internal components resting in the front panel.
    • Remove the black handle from the main external casing.
  4. Black and Decker WP900 Exterior Casing Replacement: passo 4, imagem 1 %32
    • Using the Phillips #1 screwdriver, remove the two 22mm screws.
    • The metal bracket will detach with the two screws.
    • Using the Flathead 3/32" screwdriver, remove two 22mm screws.
  5. Black and Decker WP900 Exterior Casing Replacement: passo 5, imagem 1 %32 Black and Decker WP900 Exterior Casing Replacement: passo 5, imagem 2 %32
    • Gently pull the power cord out from the control module.
    • Remember, when reassembling the device, the black wire should be on the top.
  6. Black and Decker WP900 Exterior Casing Replacement: passo 6, imagem 1 %32
    • Firmly grasping the motor dislodge the internal components from the frontal external casing.
    • Once the motor has been removed, the external casing can now be replaced.
Conclusão
David Hutchings
Membro desde: 03/28/16
101 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team 8-8, Wilson Spring 2016 Membro de IUPUI, Team 8-8, Wilson Spring 2016
IUPUI-WILSON-S16S8G8
Membros da 4
Autoria de 4 guias
Um comentário
Hello, this is Adam Kinnett from Group 7. You have done an excellent job on your photos as well as the descriptions and formatting.
**One of your Wiki pages on the search says "Back and Decker".
Adam Kinnett - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 8
Duração total: 842
