Ir para o conteúdo principal
Black and Decker Toast R Oven Knobs Replacement
O que você precisa
  1. Black and Decker Toast R Oven Knobs Replacement, Knobs: passo 1, imagem 1 %32
    • Make sure that the toaster is unplugged before you begin.
    • Turn the toaster upside down and remove the two Phillips #4 1 cm screws attached to the side panels.
  2. Black and Decker Toast R Oven Knobs Replacement: passo 2, imagem 1 %32 Black and Decker Toast R Oven Knobs Replacement: passo 2, imagem 2 %32
    • Pull down and out to remove side panels from the unit
    • Repeat for the other side.
  3. Black and Decker Toast R Oven Knobs Replacement: passo 3, imagem 1 %32
    • Remove the bottom vent.
    • This should come off fairly easy.
  4. Black and Decker Toast R Oven Knobs Replacement: passo 4, imagem 1 %32
    • Remove the two Phillips #4 1 cm screws that connect the bottom panel to the unit.
  5. Black and Decker Toast R Oven Knobs Replacement: passo 5, imagem 1 %32
    • Remove the crumb tray (bottom metal panel) from the toaster unit.
  6. Black and Decker Toast R Oven Knobs Replacement: passo 6, imagem 1 %32
    • Remove the aluminum strip on the bottom of the unit.
  7. Black and Decker Toast R Oven Knobs Replacement: passo 7, imagem 1 %32
    • Remove knobs by pulling up on them.
  8. Black and Decker Toast R Oven Knobs Replacement: passo 8, imagem 1 %32
    • Unhook the bottom of the display panel from the toaster unit.
    • It will be a little tough to pry off, but don't be afraid to be forceful.
  9. Black and Decker Toast R Oven Knobs Replacement: passo 9, imagem 1 %32
    • Begin to detach the back panel from the toaster unit and unhook the rest of the display panel.
    • This will also be a little tough to get off, but don't be afraid to be forceful.
Conclusão
To reassemble your toaster, follow these directions in reverse.
Uma outra pessoa concluiu este guia.
Jonathan
Membro desde: 09/18/12
281 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 2-10, Propen Fall 2012 Membro de Cal Poly, Team 2-10, Propen Fall 2012
CPSU-PROPEN-F12S2G10
Membros da 4
Autoria de 5 guias
Um comentário
very interesting post
James Evans - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 22
Duração total: 4,811
