Ir para o conteúdo principal
Black and Decker Toast R Oven Door Replacement
O que você precisa
  1. Black and Decker Toast R Oven Door Replacement, How to clean out a Black and Decker Toast R Oven: passo 1, imagem 1 %32
    • Make sure that the toaster is unplugged before you begin.
    • Turn the toaster over with its backside face down.
    • Remove the two Phillips #4 1cm screws that attach the side panels.
  2. Black and Decker Toast R Oven Door Replacement: passo 2, imagem 1 %32 Black and Decker Toast R Oven Door Replacement: passo 2, imagem 2 %32
    • Pull downwards (towards the bottom of the unit) and outward to remove the side panels.
  3. Black and Decker Toast R Oven Door Replacement: passo 3, imagem 1 %32
    • Remove the metal vent piece that is below the door.
    • This should slide off easily once both of the side panels are removed.
  4. Black and Decker Toast R Oven Door Replacement: passo 4, imagem 1 %32
    • Remove the two Phillips #4 1 cm screws, which connect the bottom panel to the unit.
  5. Black and Decker Toast R Oven Door Replacement: passo 5, imagem 1 %32
    • Remove the crumb tray (the bottom, metal panel) from the toaster unit.
  6. Black and Decker Toast R Oven Door Replacement: passo 6, imagem 1 %32
    • Remove the aluminum strip from the bottom of unit; this is the piece that is directly under the door.
  7. Black and Decker Toast R Oven Door Replacement: passo 7, imagem 1 %32
    • Remove the knobs by pulling them upward; they should slide right off.
    • When placing the knobs back on the unit, make sure the semicircle notch fits correctly in the hole so that the knobs don't fall off.
  8. Black and Decker Toast R Oven Door Replacement: passo 8, imagem 1 %32
    • Unhook the bottom of the the display panel from the toaster unit.
    • It will be a little tough to pry off, but don't be afraid to be forceful. You can use your hands, or pliers, to bend the metal piece backwards.
  9. Black and Decker Toast R Oven Door Replacement: passo 9, imagem 1 %32
    • Begin to detach the back panel from the toaster unit.
    • Then, unhook the rest of the display panel.
    • This will also be a little tough to get off, but don't be afraid to be forceful.
  10. Black and Decker Toast R Oven Door Replacement: passo 10, imagem 1 %32
    • Finish removing the outside cover by lifting the lid upward.
  11. Black and Decker Toast R Oven Door Replacement: passo 11, imagem 1 %32
    • Remove the four Phillips #4 1 cm screws from the back of the unit.
  12. Black and Decker Toast R Oven Door Replacement: passo 12, imagem 1 %32
    • Now, you can clean the outside units of the toaster oven.
  13. Black and Decker Toast R Oven Door Replacement: passo 13, imagem 1 %32
    • Remove the the heating coil protection bar from the toaster unit by first pulling out the left side.
  14. Black and Decker Toast R Oven Door Replacement, Door Spring Mechanism: passo 14, imagem 1 %32 Black and Decker Toast R Oven Door Replacement, Door Spring Mechanism: passo 14, imagem 2 %32
    • Use the screwdriver to remove the spring from the unit.
    • Place the screwdriver inside the spring loop.
    • Pull to unhinge the spring from the back panel.
  15. Black and Decker Toast R Oven Door Replacement: passo 15, imagem 1 %32
    • Remove the spring from the door mechanism by pulling it off.
    • Replace the old spring with a new spring.
    • When inserting a new spring, make sure that the spring is connected to the lower hole of the back panel (the hole above is used for the back casing).
  16. Black and Decker Toast R Oven Door Replacement, Door: passo 16, imagem 1 %32 Black and Decker Toast R Oven Door Replacement, Door: passo 16, imagem 2 %32
    • Use the pliers and a wrench to straighten the outdoor mechanism.
  17. Black and Decker Toast R Oven Door Replacement: passo 17, imagem 1 %32
    • Take off the left side of the door by separating the unit from the hinge.
  18. Black and Decker Toast R Oven Door Replacement: passo 18, imagem 1 %32
    • Separate the right side of the door from the unit as in the previous step.
  19. Black and Decker Toast R Oven Door Replacement: passo 19, imagem 1 %32
    • Separate the door mechanism from the door by tilting the door to relieve the mechanism.
  20. Black and Decker Toast R Oven Door Replacement: passo 20, imagem 1 %32
    • Unscrew the two door-handle screws.
Conclusão
4 outras pessoas executaram este guia.
Jonathan
Membro desde: 09/18/12
281 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 2-10, Propen Fall 2012 Membro de Cal Poly, Team 2-10, Propen Fall 2012
CPSU-PROPEN-F12S2G10
Membros da 4
Autoria de 5 guias
2 comentários
sale humo al momento de prender el horno
alo_68salud - Responder
Thanks - you guide helped me ix my toaster oven.
Brian - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 32
Duração total: 6,976
