Introdução
To work on the inside of the toaster, the top cover must first be removed. This guide provides instructions on how to remove the top cover.
O que você precisa
Turn the toaster upside down.
Unscrew all four 4mm screws on the bottom using a Phillip's head #2 (PH2) screwdriver.
Or a slightly different model has six screws that require an allen wrench (hex key). Ones that have a ball end will not work. I had to use one that had more of a Star of David, pointy pattern to it.
3 outras pessoas executaram este guia.
