Ir para o conteúdo principal
Black and Decker TR1278B Bread Grabber Spring Replacement
O que você precisa
  1. Black and Decker TR1278B Bread Grabber Spring Replacement, Top Cover: passo 1, imagem 1 %32
    • Unplug the toaster before disassembly.
    • Remove the carriage lever by pulling it away from the toaster.
  2. Black and Decker TR1278B Bread Grabber Spring Replacement: passo 2, imagem 1 %32
    • Toaster will be turned upside down. Clear crumb tray or work over a paper towel.
    • Turn the toaster upside down.
    • Unscrew all four 4mm screws on the bottom using a Phillip's head #2 (PH2) screwdriver.
    • Or a slightly different model has six screws that require an allen wrench (hex key). Ones that have a ball end will not work. I had to use one that had more of a Star of David, pointy pattern to it.
  3. Black and Decker TR1278B Bread Grabber Spring Replacement: passo 3, imagem 1 %32
    • Detach the bottom from the front cover using the plastic opening tool.
  4. Black and Decker TR1278B Bread Grabber Spring Replacement: passo 4, imagem 1 %32
    • Turn the toaster right side up.
    • Support the bottom. The ribbon cable that connects the toaster to the front cover can be damaged.
    • Lift the front cover.
    • Lift carefully. Again the ribbon cable can be damaged.
  5. Black and Decker TR1278B Bread Grabber Spring Replacement: passo 5, imagem 1 %32
    • Detach the bundled cable connector from the toaster by carefully pulling it away from the circuit board.
  6. Black and Decker TR1278B Bread Grabber Spring Replacement, Bread Grabber Spring: passo 6, imagem 1 %32
    • Locate the spring
  7. Black and Decker TR1278B Bread Grabber Spring Replacement: passo 7, imagem 1 %32
    • Press down on the toaster lever to gain access to the grabber spring located behind the large metal plate.
    • Use metal spudger to loosen clamps on spring.
  8. Black and Decker TR1278B Bread Grabber Spring Replacement: passo 8, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use needle nose tweezers to pull the spring off of its hook.
    • Repeat this step for the opposite side.
  9. Black and Decker TR1278B Bread Grabber Spring Replacement: passo 9, imagem 1 %32
    • Remove the old spring from the toaster unit to insert the new one.
Conclusão
Brea-Monique
Membro desde: 02/15/17
384 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 8-1, Eyestone Spring 2017 Membro de USF Tampa, Team 8-1, Eyestone Spring 2017
USFT-EYESTONE-S17S8G1
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 24
Duração total: 1,239
