Ir para o conteúdo principal
Black and Decker SS12C Battery Replacement
O que você precisa
  1. Black and Decker SS12C Battery Replacement, Battery: passo 1, imagem 1 %32 Black and Decker SS12C Battery Replacement, Battery: passo 1, imagem 2 %32 Black and Decker SS12C Battery Replacement, Battery: passo 1, imagem 3 %32
    • Detach the battery unit from the drill by pressing down on the battery release button and pulling the battery towards you.
  2. Black and Decker SS12C Battery Replacement: passo 2, imagem 1 %32
    • Now that the battery component is detached, remove the 4 screws indicated [16mm].
    • Remove each screw with the T10 Torx Security Bit Screwdriver by turning counterclockwise.
  3. Black and Decker SS12C Battery Replacement: passo 3, imagem 1 %32 Black and Decker SS12C Battery Replacement: passo 3, imagem 2 %32 Black and Decker SS12C Battery Replacement: passo 3, imagem 3 %32
    • Now that the screws are detached, separate the two sides of the battery.
  4. Black and Decker SS12C Battery Replacement: passo 4, imagem 1 %32 Black and Decker SS12C Battery Replacement: passo 4, imagem 2 %32
    • Remove the highlighted, orange component and set aside.
  5. Black and Decker SS12C Battery Replacement: passo 5, imagem 1 %32 Black and Decker SS12C Battery Replacement: passo 5, imagem 2 %32 Black and Decker SS12C Battery Replacement: passo 5, imagem 3 %32
    • Grip the battery pack and detach it from the casing by pulling it upward.
    • Spring may fall out during the process.
Conclusão
Um comentário
I have a CD 9600 Type 3 with a B&D PS120 pack. are there any replacement packs available? Thanks!
Scott D. Deutsch - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 12
Últimos 30 dias: 23
Duração total: 840
