Introdução
The pivot button may need to be installed if problems such as jamming of the button occur. This guide will outline how to install the pivot button on the Black and Decker Pivot Plus PD600.
Peças
Não são necessárias peças.
  1. Remove the screw located on the opposite side of the black half of the button with the lock symbol with the Phillips #1 screwdriver. Remove the screw located on the opposite side of the black half of the button with the lock symbol with the Phillips #1 screwdriver.
    • Remove the screw located on the opposite side of the black half of the button with the lock symbol with the Phillips #1 screwdriver.
  2. Free shipping on all orders over US$100 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
  3. After the screw is removed, take off both sides of the button. You will be left with 3 pieces. Two halves of the button (a black piece with a lock on the front, and a circular orange piece) will be left over along with a spring.
    • After the screw is removed, take off both sides of the button.
    • You will be left with 3 pieces. Two halves of the button (a black piece with a lock on the front, and a circular orange piece) will be left over along with a spring.
Conclusão
Ryan Angelich
101 reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 4-15, Maness Spring 2013 Membro de Cal Poly, Team 4-15, Maness Spring 2013
CPSU-MANESS-S13S4G15
5 Membros
6 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Todo: 743
