Ir para o conteúdo principal
Black and Decker Pivot MAX Motor Replacement
O que você precisa
  1. Black and Decker Pivot MAX Motor Replacement, Battery: passo 1, imagem 1 %32 Black and Decker Pivot MAX Motor Replacement, Battery: passo 1, imagem 2 %32
    • Press in and hold the release button.
    • Rotate the dust filter chamber counter-clockwise.
    • Remove the dust filter chamber.
  2. Black and Decker Pivot MAX Motor Replacement: passo 2, imagem 1 %32
    • Remove the two 10 mm screws from the motor casing with a Phillips #1 screwdriver.
  3. Black and Decker Pivot MAX Motor Replacement: passo 3, imagem 1 %32
    • Pull the battery cover up and then slide it away from the motor to remove.
  4. Black and Decker Pivot MAX Motor Replacement: passo 4, imagem 1 %32
    • Remove the battery unit by pulling it out of the main body.
  5. Black and Decker Pivot MAX Motor Replacement: passo 5, imagem 1 %32
    • Disconnect the quick connect wire harness that connects the motor and battery located in the battery storage compartment.
  6. Black and Decker Pivot MAX Motor Replacement, Pivot Lock Button: passo 6, imagem 1 %32
    • Remove the handle cover by removing the three PH1 20mm screws
  7. Black and Decker Pivot MAX Motor Replacement: passo 7, imagem 1 %32
    • Pull out the pivot lock button.
  8. Black and Decker Pivot MAX Motor Replacement, Motor: passo 8, imagem 1 %32 Black and Decker Pivot MAX Motor Replacement, Motor: passo 8, imagem 2 %32
    • Gently lift the battery tray from the chassis.
  9. Black and Decker Pivot MAX Motor Replacement: passo 9, imagem 1 %32 Black and Decker Pivot MAX Motor Replacement: passo 9, imagem 2 %32
    • Pull the pivot linkage from the handle.
  10. Black and Decker Pivot MAX Motor Replacement: passo 10, imagem 1 %32
    • Remove the grey handle and set it aside.
  11. Black and Decker Pivot MAX Motor Replacement: passo 11, imagem 1 %32
    • Remove four Phillips #1 screws from the motor housing.
  12. Black and Decker Pivot MAX Motor Replacement: passo 12, imagem 1 %32
    • Lift the motor housing straight up to remove it from the rest of the vacuum.
  13. Black and Decker Pivot MAX Motor Replacement: passo 13, imagem 1 %32 Black and Decker Pivot MAX Motor Replacement: passo 13, imagem 2 %32
    • Gently pull the red and black wires from the top of the motor.
  14. Black and Decker Pivot MAX Motor Replacement: passo 14, imagem 1 %32
    • Lift the motor casing from the outer shell of the vacuum by pulling up on the motor casing away from the outer shell.
  15. Black and Decker Pivot MAX Motor Replacement: passo 15, imagem 1 %32 Black and Decker Pivot MAX Motor Replacement: passo 15, imagem 2 %32
    • Turn over the motor casing and locate the fan disc underneath where the motor was.
  16. Black and Decker Pivot MAX Motor Replacement: passo 16, imagem 1 %32
    • Insert one metal spudger underneath the fan disc located on the opposite side of the motor.
  17. Black and Decker Pivot MAX Motor Replacement: passo 17, imagem 1 %32
    • Use a second metal spudger to pry up the fan disc.
  18. Black and Decker Pivot MAX Motor Replacement: passo 18, imagem 1 %32
    • Pull up on the fan disc to reveal the motor screws.
  19. Black and Decker Pivot MAX Motor Replacement: passo 19, imagem 1 %32
    • Remove the two 20mm Phillips #1 screws from the bottom of the motor under the fan disc.
  20. Black and Decker Pivot MAX Motor Replacement: passo 20, imagem 1 %32
    • Flip over the motor casing and remove the motor to be replaced.
Conclusão
Uma outra pessoa concluiu este guia.
3 comentários
Unbelievable! They sell a replacement motor but not replacement batteries! Wow!
Robert Birmingham - Responder
I needed to access the ultimate exit of the unit to clean and clear the filtration media, but was unsuccessful. Can the issue be clarified? My email address is 8tolive@gmail.com
R. J. W. - Responder
Can you provide a link to the exact replacement motor part?
Guy Landis - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 24
Últimos 30 dias: 81
Ao todo: 4,127
