Ir para o conteúdo principal
Black and Decker Pivot MAX Battery Replacement
O que você precisa
  1. Black and Decker Pivot MAX Battery Replacement, Battery: passo 1, imagem 1 %32 Black and Decker Pivot MAX Battery Replacement, Battery: passo 1, imagem 2 %32
    • Press in and hold the release button.
    • Rotate the dust filter chamber counter-clockwise.
    • Remove the dust filter chamber.
  2. Black and Decker Pivot MAX Battery Replacement: passo 2, imagem 1 %32
    • Remove the two 10 mm screws from the motor casing with a Phillips #1 screwdriver.
  3. Black and Decker Pivot MAX Battery Replacement: passo 3, imagem 1 %32
    • Pull the battery cover up and then slide it away from the motor to remove.
  4. Black and Decker Pivot MAX Battery Replacement: passo 4, imagem 1 %32
    • Remove the battery unit by pulling it out of the main body.
  5. Black and Decker Pivot MAX Battery Replacement: passo 5, imagem 1 %32
    • Disconnect the quick connect wire harness that connects the motor and battery located in the battery storage compartment.
Conclusão
25 outras pessoas executaram este guia.
Jesse Sipes
Membro desde: 11/06/17
586 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team S5-G6, Baechle Fall 2017 Membro de IUPUI, Team S5-G6, Baechle Fall 2017
IUPUI-BAECHLE-F17S5G6
3 Membros
Autoria de 7 guias
28 comentários
any idea where to find the replacement battery? Does it come as a unit or do you need to disassemble the battery pack and replace the cells?
DMcDermott - Responder
Where do I get the cells to replace the old ones?
Patricia Leat - Responder
How do you disconnect the quick connect
DJ SmashBeatz - Responder
My battery pack is soldered to a circuit board. There is no quick connect. (Model BDH2000PL, Type 2).
HBL - Responder
Same here. Worst design ever.
James Watson -
Comentar
Exibir estatísticas:
Últimas 24 horas: 28
Últimos 7 dias: 127
Últimos 30 dias: 614
Ao todo: 51,642
