Ir para o conteúdo principal
Black and Decker PS1800 Motor Replacement
O que você precisa
  1. Black and Decker PS1800 Motor Replacement, Open the Outer Drill Case: passo 1, imagem 1 %32 Black and Decker PS1800 Motor Replacement, Open the Outer Drill Case: passo 1, imagem 2 %32
    • Lay the drill on its side, assuring that the screw holes are facing upwards.
    • Remove seven 12 mm screws using a Phillips #00 screwdriver.
  2. Black and Decker PS1800 Motor Replacement: passo 2, imagem 1 %32
    • Separate the outer drill case to expose the components and switch.
  3. Black and Decker PS1800 Motor Replacement, Disconnect Motor: passo 3, imagem 1 %32 Black and Decker PS1800 Motor Replacement, Disconnect Motor: passo 3, imagem 2 %32 Black and Decker PS1800 Motor Replacement, Disconnect Motor: passo 3, imagem 3 %32
    • Locate the motor at the top left hand corner.
    • Carefully disconnect the red and black wires attached to the motor.
  4. Black and Decker PS1800 Motor Replacement: passo 4, imagem 1 %32
    • Unscrew the motor from the drill's transmission.
    • Detach the transmission carefully, ensuring that the gears remain intact.
  5. Black and Decker PS1800 Motor Replacement: passo 5, imagem 1 %32 Black and Decker PS1800 Motor Replacement: passo 5, imagem 2 %32
    • Remove the motor from the transmission assembly, as pictured.
Conclusão
Uma outra pessoa concluiu este guia.
Christian Aldrich
Membro desde: 10/12/16
253 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team 2-3, Baechle Fall 2016 Membro de IUPUI, Team 2-3, Baechle Fall 2016
IUPUI-BAECHLE-F16S2G3
Membros da 5
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 26
Duração total: 1,867
