Ir para o conteúdo principal
Black and Decker PS1800 Actuator Fwd/Rev Replacement
O que você precisa
  1. Black and Decker PS1800  Actuator Fwd/Rev Replacement, Open the Outer Drill Case: passo 1, imagem 1 %32 Black and Decker PS1800  Actuator Fwd/Rev Replacement, Open the Outer Drill Case: passo 1, imagem 2 %32
    • Lay the drill on its side, assuring that the screw holes are facing upwards.
    • Remove seven 12 mm screws using a Phillips #00 screwdriver.
  2. Black and Decker PS1800  Actuator Fwd/Rev Replacement: passo 2, imagem 1 %32
    • Separate the outer drill case to expose the components and switch.
  3. Black and Decker PS1800  Actuator Fwd/Rev Replacement, Actuator Fwd/Rev: passo 3, imagem 1 %32 Black and Decker PS1800  Actuator Fwd/Rev Replacement, Actuator Fwd/Rev: passo 3, imagem 2 %32 Black and Decker PS1800  Actuator Fwd/Rev Replacement, Actuator Fwd/Rev: passo 3, imagem 3 %32
    • Start separating the outer shell into two parts.
    • You will find the Fwd/Rev actuator on the right side of the drill, underneath the motor.
  4. Black and Decker PS1800  Actuator Fwd/Rev Replacement: passo 4, imagem 1 %32 Black and Decker PS1800  Actuator Fwd/Rev Replacement: passo 4, imagem 2 %32 Black and Decker PS1800  Actuator Fwd/Rev Replacement: passo 4, imagem 3 %32
    • Carefully remove the actuator from the drill.
    • Replace the new actuator by inserting it the same way you took it out.
Conclusão
Hamza Nawaz
Membro desde: 11/20/16
247 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team 2-3, Baechle Fall 2016 Membro de IUPUI, Team 2-3, Baechle Fall 2016
IUPUI-BAECHLE-F16S2G3
5 Membros
Autoria de 6 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 13
Ao todo: 854
