Ir para o conteúdo principal
Black and Decker LI4000 Outer Casing Replacement
O que você precisa
  1. Black and Decker LI4000 Outer Casing Replacement, Outer Casing: passo 1, imagem 1 %32 Black and Decker LI4000 Outer Casing Replacement, Outer Casing: passo 1, imagem 2 %32 Black and Decker LI4000 Outer Casing Replacement, Outer Casing: passo 1, imagem 3 %32
    • Remove the stickers found on the bottom and sides of the LI4000, using a spudger.
  2. Black and Decker LI4000 Outer Casing Replacement: passo 2, imagem 1 %32
    • Remove all six of the 12-mm long case screws with a Philips #1 Screwdriver. These screws can be found on the side of the LI4000 with the "Warning" sticker.
  3. Black and Decker LI4000 Outer Casing Replacement: passo 3, imagem 1 %32 Black and Decker LI4000 Outer Casing Replacement: passo 3, imagem 2 %32
    • Remove the two screws that are 4-mm Hexagonal #2.5. These are very small case screws that can be found underneath the two stickers from Step 1.
  4. Black and Decker LI4000 Outer Casing Replacement: passo 4, imagem 1 %32 Black and Decker LI4000 Outer Casing Replacement: passo 4, imagem 2 %32
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but the regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Pry on the seam as shown with a Spudger, in order to get the top casing loose.
    • Pull the two sides apart while making sure the side that you are removing is the one with all of the case screw holes.
    • It is good practice to remove the top connection of the battery as shown in the third image, as this will be the first step to replacing any of the components for this screwdriver.
Conclusão
Bryan Beard
Membro desde: 02/11/16
107 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team 2-3, Baechle Spring 2016 Membro de IUPUI, Team 2-3, Baechle Spring 2016
IUPUI-BAECHLE-S16S2G3
Membros da 3
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 25
Duração total: 337
