Introdução
Use this guide to remove or replace the battery in your Black and Decker LI2000.
O que você precisa
Remove the following five screws
Three 20 mm Phillips #1 screws
One 10 mm #000 Phillips screw
One 13 mm Phillips 31 screw
5 outras pessoas executaram este guia.
3 comentários
It would be great is you could discuss the 3.6v cell - Lithium Type -- Size? Is it an 18650?
OK, so where can we get the battery!?
Check eBay for the 18650 with solder tabs already attached. I purchased a 4 pack of the batteries and used 1 for a LI3100. I needed a Dremel tool to remove some of the internal plastic battery supports to accommodate this battery. If the solder tabs had been oriented 180 degrees to each other, it would have been a drop in fit. Screwdriver works great now!
