Introdução
If the saw has a broken shoe plate, this guide will show you how to replace it. It is simply two screws that must be removed in order to remove the entire plate.
O que você precisa
Remove the nine torx 15.875mm screws on the front of the jigsaw using a T-15 torx screwdriver.
Remove the 6.3mm hex screw on the left with a H.30 hex screwdriver.
Remove the reverse threaded 6.9mm black hex screw on the right with a H.40 hex screwdriver.
