Ir para o conteúdo principal
Black and Decker JS660 Power Cord Replacement
O que você precisa
  1. Black and Decker JS660 Power Cord Replacement, Housing Disassembly: passo 1, imagem 1 %32 Black and Decker JS660 Power Cord Replacement, Housing Disassembly: passo 1, imagem 2 %32
    • Remove the nine torx 15.875mm screws on the front of the jigsaw using a T-15 torx screwdriver.
  2. Black and Decker JS660 Power Cord Replacement: passo 2, imagem 1 %32
    • By separating the two housing halves, carefully remove the top plate.
  3. Black and Decker JS660 Power Cord Replacement, Power Cord: passo 3, imagem 1 %32
    • Remove the two 12.7mm phillips head screws holding the power cord in place with a PH2 Phillips head screwdriver.
  4. Black and Decker JS660 Power Cord Replacement: passo 4, imagem 1 %32
    • Remove the two 6.35mm flat head screws on the trigger with a 2.5 flat head screwdriver to disconnect the white and black cords.
  5. Black and Decker JS660 Power Cord Replacement: passo 5, imagem 1 %32
    • Gently remove the black and white cord from the trigger assembly.
Conclusão
Uma outra pessoa concluiu este guia.
matt murray
Membro desde: 01/27/17
682 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 22-9, Maness Winter 2017 Membro de Cal Poly, Team 22-9, Maness Winter 2017
CPSU-MANESS-W17S22G9
4 Membros
Autoria de 7 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 9
Ao todo: 945
