Ir para o conteúdo principal
Black and Decker JS660 Gear Box Replacement
O que você precisa
  1. Black and Decker JS660 Gear Box Replacement, Housing Disassembly: passo 1, imagem 1 %32 Black and Decker JS660 Gear Box Replacement, Housing Disassembly: passo 1, imagem 2 %32
    • Remove the nine torx 15.875mm screws on the front of the jigsaw using a T-15 torx screwdriver.
  2. Black and Decker JS660 Gear Box Replacement: passo 2, imagem 1 %32
    • By separating the two housing halves, carefully remove the top plate.
  3. Black and Decker JS660 Gear Box Replacement, Blade Holder: passo 3, imagem 1 %32
    • Being careful to keep all parts together, grab the entire assembly and pull it directly out of the saw.
  4. Black and Decker JS660 Gear Box Replacement, Motor: passo 4, imagem 1 %32
    • Remove the two 30.1625mm screws with a T20 torx screwdriver that are holding the gearbox to the housing.
  5. Black and Decker JS660 Gear Box Replacement: passo 5, imagem 1 %32
    • Apply a light force to separate the gearbox from the housing. This will momentarily separate the gearbox and help with the removal of the system in later steps.
  6. Black and Decker JS660 Gear Box Replacement: passo 6, imagem 1 %32 Black and Decker JS660 Gear Box Replacement: passo 6, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using tweezers or a small flathead screwdriver, gently remove each of the black magnetic clasps away from the motor.
  7. Black and Decker JS660 Gear Box Replacement: passo 7, imagem 1 %32
    • Holding the gearbox and the bering, pull the whole motor and gearbox out of the housing.
  8. Black and Decker JS660 Gear Box Replacement: passo 8, imagem 1 %32
    • While holding the motor in one hand, gently pull the gearbox off of the drive shaft.
Conclusão
Uma outra pessoa concluiu este guia.
matt murray
Membro desde: 01/27/17
682 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 22-9, Maness Winter 2017 Membro de Cal Poly, Team 22-9, Maness Winter 2017
CPSU-MANESS-W17S22G9
Membros da 4
Autoria de 7 guias
Um comentário
Hi. Can you please describe how to replace motor for BELTSANDER. Thanks. Chris
Chris Breedt - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 21
Duração total: 1,618
