Ir para o conteúdo principal
Black and Decker JS660 Angle Knob Replacement
O que você precisa
  1. Black and Decker JS660 Angle Knob Replacement, Base: passo 1, imagem 1 %32 Black and Decker JS660 Angle Knob Replacement, Base: passo 1, imagem 2 %32
    • Unscrew the eight screws to open up the jigsaw.
  2. Black and Decker JS660 Angle Knob Replacement: passo 2, imagem 1 %32
    • Use a screwdriver to remove the first screws securing the base to the jigsaw.
    • Remove the second screw.
    • Remove the base of the jigsaw.
  3. Black and Decker JS660 Angle Knob Replacement: passo 3, imagem 1 %32 Black and Decker JS660 Angle Knob Replacement: passo 3, imagem 2 %32
    • With the old jigsaw base off, replace it with the new base by following the steps in the reverse order.
    • Assemble the base on a steady surface.
  4. Black and Decker JS660 Angle Knob Replacement, Angle Knob: passo 4, imagem 1 %32 Black and Decker JS660 Angle Knob Replacement, Angle Knob: passo 4, imagem 2 %32 Black and Decker JS660 Angle Knob Replacement, Angle Knob: passo 4, imagem 3 %32
    • As soon you disassemble the device, you can see the angle knob is not attached to any screws.
    • Remove the angle knob from the device.
Conclusão
Andrew Khouri
Membro desde: 02/08/16
468 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 6-2, Eyestone Spring 2016 Membro de USF Tampa, Team 6-2, Eyestone Spring 2016
USFT-EYESTONE-S16S6G2
4 Membros
Autoria de 4 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 13
Ao todo: 429
