Ir para o conteúdo principal
Black and Decker JE2200B Saftey Locking Latches Replacement
O que você precisa
  1. Black and Decker JE2200B Saftey Locking Latches Replacement, Saftey Locking Latches: passo 1, imagem 1 %32 Black and Decker JE2200B Saftey Locking Latches Replacement, Saftey Locking Latches: passo 1, imagem 2 %32
    • Unlock the latches on the juicer by places hands under latches and pulling out.
  2. Black and Decker JE2200B Saftey Locking Latches Replacement: passo 2, imagem 1 %32 Black and Decker JE2200B Saftey Locking Latches Replacement: passo 2, imagem 2 %32
    • Grasp the latch close to the juicer with your right thumb and pointer finger and pull to the right.
    • With your other hand, take the plastic opening tool and insert it on the bottom of the latch.
  3. Black and Decker JE2200B Saftey Locking Latches Replacement: passo 3, imagem 1 %32
    • Push the tool up to remove the latch.
    • Repeat Step 2 for the second safety locking latch.
    • Use gentle force to remove the latches from the juicer to avoid damage to the machine.
Conclusão
AvaAnne Hogue
Membro desde: 08/27/15
544 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 5-5, Blackwell Fall 2015 Membro de USF Tampa, Team 5-5, Blackwell Fall 2015
USFT-BLACKWELL-F15S5G5
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Duração total: 467
