Ir para o conteúdo principal
Black and Decker Dustbuster CHV1510 Vacuum Rubber Seal Replacement
O que você precisa
  1. Black and Decker Dustbuster CHV1510 Vacuum Rubber Seal  Replacement, Vacuum Rubber Seal: passo 1, imagem 1 %32
    • Press the grey buttons with the unlock symbols on both sides of the nozzle.
    • Pull the nozzle upwards.
    • The other button cannot be seen on the image.
  2. Black and Decker Dustbuster CHV1510 Vacuum Rubber Seal  Replacement: passo 2, imagem 1 %32 Black and Decker Dustbuster CHV1510 Vacuum Rubber Seal  Replacement: passo 2, imagem 2 %32 Black and Decker Dustbuster CHV1510 Vacuum Rubber Seal  Replacement: passo 2, imagem 3 %32
    • Use a plastic opening tool to pry the clear rubber seal away from the white plastic nozzle.
  3. Black and Decker Dustbuster CHV1510 Vacuum Rubber Seal  Replacement: passo 3, imagem 1 %32
    • Remove the clear seal from the nozzle.
    • If the nozzle does not connect to vacuum barrel while reassembling, readjust the rubber seal and try to attach the nozzle until the two snap into place.
Conclusão
To reassemble your device, follow these instructions in reverse order. While reassembling, if the nozzle does not connect to vacuum barrel, readjust the rubber seal and try to attach the nozzle until the two snap into place.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 7
Últimos 30 dias: 14
Duração total: 367
