Ir para o conteúdo principal
Black and Decker Dustbuster CHV1510 Power Button Assembly Replacement
O que você precisa
  1. Black and Decker Dustbuster CHV1510 Power Button Assembly Replacement, Black and Decker Dustbuster CHV1510 Outer Shell Removal: passo 1, imagem 1 %32 Black and Decker Dustbuster CHV1510 Power Button Assembly Replacement, Black and Decker Dustbuster CHV1510 Outer Shell Removal: passo 1, imagem 2 %32
    • Remove nozzle by pressing two blue buttons with unlock symbols on the side of the nozzle.
    • Pull the nozzle upward.
    • The other button cannot be seen on the image.
  2. Black and Decker Dustbuster CHV1510 Power Button Assembly Replacement: passo 2, imagem 1 %32
    • Remove the six exterior 2 mm Phillips #1 screws that secure the two halves of the outer shell.
  3. Black and Decker Dustbuster CHV1510 Power Button Assembly Replacement: passo 3, imagem 1 %32 Black and Decker Dustbuster CHV1510 Power Button Assembly Replacement: passo 3, imagem 2 %32
    • Separate the two halves of the outer shell by pulling them apart.
  4. Black and Decker Dustbuster CHV1510 Power Button Assembly Replacement: passo 4, imagem 1 %32
    • Remove the grey handle by lifting it towards yourself.
    • Be cognizant of the compressed spring in the handle assembly to prevent it from ejecting.
  5. Black and Decker Dustbuster CHV1510 Power Button Assembly Replacement: passo 5, imagem 1 %32
    • Remove the switch assembly from inside the grey handle.
  6. Black and Decker Dustbuster CHV1510 Power Button Assembly Replacement, Power Button Assembly: passo 6, imagem 1 %32 Black and Decker Dustbuster CHV1510 Power Button Assembly Replacement, Power Button Assembly: passo 6, imagem 2 %32 Black and Decker Dustbuster CHV1510 Power Button Assembly Replacement, Power Button Assembly: passo 6, imagem 3 %32
    • Open the black assembly by prying the two halves apart with an opening tool.
    • Note which wire connects to each tab to avoid confusion later.
  7. Black and Decker Dustbuster CHV1510 Power Button Assembly Replacement: passo 7, imagem 1 %32 Black and Decker Dustbuster CHV1510 Power Button Assembly Replacement: passo 7, imagem 2 %32
    • Gently pull the yellow wire on the right out of the assembly for removal.
  8. Black and Decker Dustbuster CHV1510 Power Button Assembly Replacement: passo 8, imagem 1 %32 Black and Decker Dustbuster CHV1510 Power Button Assembly Replacement: passo 8, imagem 2 %32 Black and Decker Dustbuster CHV1510 Power Button Assembly Replacement: passo 8, imagem 3 %32
    • Gently pull the red wire with the black wire casing in the middle out of the assembly for removal.
  9. Black and Decker Dustbuster CHV1510 Power Button Assembly Replacement: passo 9, imagem 1 %32 Black and Decker Dustbuster CHV1510 Power Button Assembly Replacement: passo 9, imagem 2 %32
    • Gently pull the red wire on the left out of the assembly for removal.
Conclusão
To reassemble this device, follow these instructions in reverse order. Make sure you keep track of which wire belongs to which flat metal assembly tab, to ensure each wire is grounded so power is connected properly.
0 comentários
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 32
Ao todo: 1,006
