Ir para o conteúdo principal
Black and Decker DustBuster 15.6V Suction Rubber Seal Replacement
O que você precisa
  1. Black and Decker DustBuster 15.6V Suction Rubber Seal Replacement, Suction Rubber Seal: passo 1, imagem 1 %32
    • Press to blue unlock buttons at the base of the nozzle in word and pull forward .
  2. Black and Decker DustBuster 15.6V Suction Rubber Seal Replacement: passo 2, imagem 1 %32
    • Locate rubber suction seal.
  3. Black and Decker DustBuster 15.6V Suction Rubber Seal Replacement: passo 3, imagem 1 %32
    • Insert a metal spudger in between white plastic and rubber seal and gently drag spudger around see you lifting gently much like opening a can.
  4. Black and Decker DustBuster 15.6V Suction Rubber Seal Replacement: passo 4, imagem 1 %32
    • Align slits on the bottom of new suction seal then press into those slits.
    • The seal should not come above white plastic.
    • If the nozzle does not connect to vacuum barrel, readjust seal and try to attach nozzle until it snaps into place.
Conclusão
Roberto Perez
Membro desde: 03/31/17
101 Reputação
Autoria de 1 guia
Equipe
Um comentário
Where can I buy a new suction seal.
Alison Junk - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 19
Últimos 30 dias: 37
Duração total: 2,311
