Ir para o conteúdo principal
Black and Decker DustBuster 15.6V Nozzle Brush Replacement
O que você precisa
  1. Black and Decker DustBuster 15.6V Nozzle Brush Replacement, Nozzle Brush: passo 1, imagem 1 %32
    • Lift Nozzle Brush until it clicks into fully erect position.
  2. Black and Decker DustBuster 15.6V Nozzle Brush Replacement: passo 2, imagem 1 %32
    • Apply a gentle, equal pressure outward, to the inside of both brush legs.
  3. Black and Decker DustBuster 15.6V Nozzle Brush Replacement: passo 3, imagem 1 %32
    • Remove one of the leg prongs from the hole it is inserted into.
  4. Black and Decker DustBuster 15.6V Nozzle Brush Replacement: passo 4, imagem 1 %32
    • Rotate the free leg forwards or backwards from the hole.
    • This relieves the pressure from the inside of the legs allowing you to freely remove the last leg from its hole.
  5. Black and Decker DustBuster 15.6V Nozzle Brush Replacement: passo 5, imagem 1 %32
    • Check each leg hole for debris and clear whats needed.
    • Insert a leg of the new brush into the correct hole, so the brush will click into its erect position.
    • Slide the other leg into its respective hole.
Conclusão
Jacob
Membro desde: 03/15/17
101 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 354
