Introdução
This guide will take you through the process of replacing the powerhead assembly on the Black and Decker BV2500 Type 4. The powerhead assembly contains all the internal components and you can buy it separately. This will save you from buying costly individual parts.
O que você precisa
Using a Phillips #2 screwdriver, remove the six 20 mm screws in the black plastic casing (clamshell).
The powerhead assembly is the entire orange part of the device.
Replace it with a new powerhead assembly.
