Introdução
This guide will take you through the process of replacing the powerhead assembly on the Black and Decker BV2500 Type 4. The powerhead assembly contains all the internal components and you can buy it separately. This will save you from buying costly individual parts.
  1. Locate and unscrew the six 20 mm Phillips #2 screws in the black plastic casing (clamshell) with a Phillips #2 screwdriver.
    • Locate and unscrew the six 20 mm Phillips #2 screws in the black plastic casing (clamshell) with a Phillips #2 screwdriver.
  2. Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
  3. Using your hands, remove the blower tube and clamshell. To remove the clamshell, pull apart starting from the bottom until it is pulled out from the notches. Then slide it out away from the device.
    • Using your hands, remove the blower tube and clamshell.
      • To remove the clamshell, pull apart starting from the bottom until it is pulled out from the notches. Then slide it out away from the device.
  4. The powerhead assembly is the entire orange part of the device.
    • The powerhead assembly is the entire orange part of the device.
    • Replace it with a new powerhead assembly.
Conclusão
Angelica Chow
363 reputação
3 Guides authored
Equipe
Cal Poly, Team 9-29, Maness Winter 2014 Membro de Cal Poly, Team 9-29, Maness Winter 2014
CPSU-MANESS-W14S9G29
4 Membros
5 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Todo: 547
