Introdução
This guide will take you through the process of replacing the clamshell on the Black and Decker BV2500 Type 4. It is important to replace the clam shell when it is damaged, if the impellor is exposed, it can be dangerous for the operator.
O que você precisa
Using a Phillips #2 screwdriver, remove the six 20 mm screws in the black plastic casing (clamshell).
Quase terminado!
Conclusão
