Ir para o conteúdo principal
Black and Decker BV2500 Type 4 Clamshell (Black Outer Casing) Replacement
O que você precisa
  1. Black and Decker BV2500 Type 4 Clamshell (Black Outer Casing) Replacement, Clamshell (Black Outer Casing): passo 1, imagem 1 %32
    • Using a Phillips #2 screwdriver, remove the six 20 mm screws in the black plastic casing (clamshell).
  2. Black and Decker BV2500 Type 4 Clamshell (Black Outer Casing) Replacement: passo 2, imagem 1 %32 Black and Decker BV2500 Type 4 Clamshell (Black Outer Casing) Replacement: passo 2, imagem 2 %32
    • Using your hands, remove the blower tube and clamshell.
    • To remove the clamshell, pull apart starting from the bottom until it is pulled out from the notches. Then slide it out away from the device.
Conclusão
Angelica Chow
Membro desde: 01/25/14
409 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 9-29, Maness Winter 2014 Membro de Cal Poly, Team 9-29, Maness Winter 2014
CPSU-MANESS-W14S9G29
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 724
