Introdução
You will need to have completed the prerequisite guides prior to this guide in order to execute it.
O que você precisa
Once you have the base removed, the circuit board should be clearly visible inside.
Once the circuit board has been freed from its screws it can be moved out of the way to gain access to the buttons.
A single screw must be removed from the top as shown.
Quase terminado!
Conclusão
