Ir para o conteúdo principal
Black and Decker BL3000S Motor Fan Replacement
O que você precisa
  1. Black and Decker BL3000S Motor Fan Replacement, Blender Base: passo 1, imagem 1 %32 Black and Decker BL3000S Motor Fan Replacement, Blender Base: passo 1, imagem 2 %32
    • Before disassembling the blender base, make sure the blender disconnected from any power outlet.
    • Lift the jar straight up from the base without tilting the jar.
  2. Black and Decker BL3000S Motor Fan Replacement: passo 2, imagem 1 %32
    • Remove the top three 1/4 inch base screws using a Philip's head screwdriver.
  3. Black and Decker BL3000S Motor Fan Replacement: passo 3, imagem 1 %32 Black and Decker BL3000S Motor Fan Replacement: passo 3, imagem 2 %32
    • Remove the two base leg covers next to the power cord using pliers or a flat-head screwdriver.
    • This provides access to the base screws beneath.
  4. Black and Decker BL3000S Motor Fan Replacement: passo 4, imagem 1 %32
    • Remove the following screws that secure the top and bottom halves of the base.
    • One 1/4 Phillips screw
    • One TA-20 screw
    • Both screwdrivers must have a minimum of a three inch shank (length).
    • Screwdrivers with extenders will not fit down the access holes.
  5. Black and Decker BL3000S Motor Fan Replacement: passo 5, imagem 1 %32
    • Lift the top half of the base from the bottom half of the base to reveal the internal mechanism.
  6. Black and Decker BL3000S Motor Fan Replacement, Motor Fan: passo 6, imagem 1 %32 Black and Decker BL3000S Motor Fan Replacement, Motor Fan: passo 6, imagem 2 %32
    • Using pliers, remove the top nut from the fan and remove the washer.
    • Use a small towel to hold the fan in place. This makes taking off the nut easier to do.
  7. Black and Decker BL3000S Motor Fan Replacement: passo 7, imagem 1 %32
    • Lift the fan blades from the blender base.
Conclusão
3 outras pessoas executaram este guia.
Andrew
Membro desde: 10/04/12
209 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 6-34, Regan Fall 2012 Membro de Cal Poly, Team 6-34, Regan Fall 2012
CPSU-REGAN-F12S6G34
Membros da 4
Autoria de 6 guias
Um comentário
mon mixeur a montre des itincelles et de la fumeé quel étape puis suivre pour le réparer
abdelkarim hassi - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 42
Duração total: 4,421
