Ir para o conteúdo principal
Black and Decker BDH9600CHV Motor Replacement
O que você precisa
  1. Black and Decker BDH9600CHV Motor Replacement, Motor: passo 1, imagem 1 %32 Black and Decker BDH9600CHV Motor Replacement, Motor: passo 1, imagem 2 %32 Black and Decker BDH9600CHV Motor Replacement, Motor: passo 1, imagem 3 %32
    • To remove the filter and housing, press the green button labeled "Filter".
  2. Black and Decker BDH9600CHV Motor Replacement: passo 2, imagem 1 %32
    • Unscrew and remove all 5 screws using the Phillips 0 screw bit. Each screw is 17.5 mm long.
  3. Black and Decker BDH9600CHV Motor Replacement: passo 3, imagem 1 %32 Black and Decker BDH9600CHV Motor Replacement: passo 3, imagem 2 %32 Black and Decker BDH9600CHV Motor Replacement: passo 3, imagem 3 %32
    • Pull the housing apart
    • When you pull apart the housing pieces could fall out. Be sure to keep track of them.
    • Remove the motor unit from the housing
    • Note that the black disk needs to be firmly pulled it will resist, but can be pulled directly off of the pin if it is pulled hard enough.
  4. Black and Decker BDH9600CHV Motor Replacement: passo 4, imagem 1 %32 Black and Decker BDH9600CHV Motor Replacement: passo 4, imagem 2 %32 Black and Decker BDH9600CHV Motor Replacement: passo 4, imagem 3 %32
    • Remove the motor from the circuit board.
    • The motor makes contact with the board at 2 points. These may be bent or distorted. Straighten them with a pair of needle nose pliers in order to remove.
Conclusão
Ivette Muzquiz
Membro desde: 11/06/17
349 Reputação
Autoria de 3 guias
Equipe
IUPUI, Team S1-G4, Harley Fall 2017 Membro de IUPUI, Team S1-G4, Harley Fall 2017
IUPUI-HARLEY-F17S1G4
3 Membros
Autoria de 3 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 20
Ao todo: 2,439
