Introdução
This guide describes how to replace the motor assembly from inside of the BLACK and DECKER BDERO100 5 inch sander. The tools that you will need for this process are the TR20 Torx Security bit driver or equivalent, the plastic spudger & the plastic opening tool.
O que você precisa
Use the nylon spudger to remove the rubber ring from the filter attachment section.
Use the bit driver with the JIS - J1 bit to remove the two 12.5 mm phillips screws holding the cord clamp to the chassis.
Um comentário
Hey, I’m planning on changing the motor on my B+D 20V Sander and it seems to be the same (or at least very similar) procedure, but I’d like to know the type of motor it needs. Do you know how can I know the specs of the motor? or is that more of a open and see kind of thing?
Thanks!
