Introdução
This guide describes how to replace the holder brush and spring assembly from the BLACK and DECKER BDERO100 5 inch sander. You will need the JIS - J1 bit driver or equivalent, TR20 Torx Security bit driver or equivalent, the plastic spudger & the plastic opening tool.
O que você precisa
Use the nylon spudger to remove the rubber ring from the filter attachment section.
Use the bit driver with the JIS - J1 bit to remove the two 12.5 mm phillips screws holding the cord clamp to the chassis.
Uma outra pessoa concluiu este guia.
