Ir para o conteúdo principal
Black and Decker BDERO100 Chassis Replacement
O que você precisa
  1. Black and Decker BDERO100 Chassis Replacement, Chassis: passo 1, imagem 1 %32 Black and Decker BDERO100 Chassis Replacement, Chassis: passo 1, imagem 2 %32
    • Use the nylon spudger to remove the rubber ring from the filter attachment section.
    • The easiest way to do this is to place the spudger sideways and pulling out the ring.
  2. Black and Decker BDERO100 Chassis Replacement: passo 2, imagem 1 %32 Black and Decker BDERO100 Chassis Replacement: passo 2, imagem 2 %32
    • Use the TR20 Torx Security bit driver to unscrew the five 18.75mm Phillips screws from the warning label side of the chassis.
  3. Black and Decker BDERO100 Chassis Replacement: passo 3, imagem 1 %32 Black and Decker BDERO100 Chassis Replacement: passo 3, imagem 2 %32
    • Grab the plastic opening tool and place it on the separation line between both sides of the chassis.
    • Separate both sides and open the device.
    • Be careful not to lose or detach any internal parts while opening the sander.
  4. Black and Decker BDERO100 Chassis Replacement: passo 4, imagem 1 %32 Black and Decker BDERO100 Chassis Replacement: passo 4, imagem 2 %32
    • Hold the chassis and separate it from the device.
Conclusão
Irene Zubillaga
Membro desde: 02/10/16
617 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 1-5, Sullivan Spring 2016 Membro de USF Tampa, Team 1-5, Sullivan Spring 2016
USFT-SULLIVAN-S16S1G5
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 8
Duração total: 473
