Ir para o conteúdo principal
Black and Decker BDEDMT Power Cord Replacement
O que você precisa
  1. Black and Decker BDEDMT Power Cord Replacement, Detach Matrix Attachment: passo 1, imagem 1 %32 Black and Decker BDEDMT Power Cord Replacement, Detach Matrix Attachment: passo 1, imagem 2 %32
    • Remember to disconnect the device from all external power sources.
    • To detach the matrix attachment piece, press down on the attachment release button located at the top of the device.
    • Leaving your finger pressed down on the button, simply pull on the attachment to release it.
  2. Black and Decker BDEDMT Power Cord Replacement, Remove Mounting Hardware: passo 2, imagem 1 %32 Black and Decker BDEDMT Power Cord Replacement, Remove Mounting Hardware: passo 2, imagem 2 %32 Black and Decker BDEDMT Power Cord Replacement, Remove Mounting Hardware: passo 2, imagem 3 %32
    • Using a JIS 1 screwdriver, unscrew seven 19mm outer screws located on the armature.
    • Using the same screwdriver, unscrew the 12mm outer screw located on the armature.
  3. Black and Decker BDEDMT Power Cord Replacement, Mounting Bracket: passo 3, imagem 1 %32 Black and Decker BDEDMT Power Cord Replacement, Mounting Bracket: passo 3, imagem 2 %32
    • Using the T-handle screwdriver with the JIS 1 bit, unscrew the two lower black 12mm screws.
  4. Black and Decker BDEDMT Power Cord Replacement: passo 4, imagem 1 %32 Black and Decker BDEDMT Power Cord Replacement: passo 4, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • There will be a white cord that runs from the power cord base to the circuit board located slightly above.
    • Use the tweezers to detach the entire white cord and blue connection piece as a whole from the circuit board.
  5. Black and Decker BDEDMT Power Cord Replacement, Trigger Assembly: passo 5, imagem 1 %32 Black and Decker BDEDMT Power Cord Replacement, Trigger Assembly: passo 5, imagem 2 %32
    • Physically pull up on the trigger device and remove it from the armature.
    • Flip trigger device over onto its back.
  6. Black and Decker BDEDMT Power Cord Replacement, Wire Removal: passo 6, imagem 1 %32 Black and Decker BDEDMT Power Cord Replacement, Wire Removal: passo 6, imagem 2 %32 Black and Decker BDEDMT Power Cord Replacement, Wire Removal: passo 6, imagem 3 %32
    • There is a screw labeled 3 located on the bottom left of the back of the trigger device.
    • Use a JIS 0 screwdriver to remove screw.
    • Gently tug on the black wire to pull the wire out of the device.
    • Now the power cord will be completely removed from the device.
Conclusão
cayla dahl
Membro desde: 02/01/16
247 Reputação
Autoria de 2 guias
Equipe
UW Tacoma, Team 1-2, Rose Winter 2016 Membro de UW Tacoma, Team 1-2, Rose Winter 2016
UWT-ROSE-W16S1G2
Membros da 4
Autoria de 11 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 33
Duração total: 2,177
