Introdução
Before diving into the replacement of your drill power cord, it will be helpful to know that this is a fairly easy replacement with few steps and few tools. Remember to disconnect the power cord from a wall outlet before disconnecting any wires.
O que você precisa
To detach the matrix attachment piece, press down on the attachment release button located at the top of the device.
Leaving your finger pressed down on the button, simply pull on the attachment to release it.
Using a JIS 1 screwdriver, unscrew seven 19mm outer screws located on the armature.
Using the same screwdriver, unscrew the 12mm outer screw located on the armature.
Using the T-handle screwdriver with the JIS 1 bit, unscrew the two lower black 12mm screws.
Physically pull up on the trigger device and remove it from the armature.
Flip trigger device over onto its back.
There is a screw labeled 3 located on the bottom left of the back of the trigger device.
Use a JIS 0 screwdriver to remove screw.
Gently tug on the black wire to pull the wire out of the device.
