Introdução
If your device has a faulty motor this is the guide for you. This guide is not very challenging. You may need this guide if your motor has a faulty piece, bad wiring, or failed gears. Replacing the motor can be taken care of in six simple steps.
Ferramentas
Peças
Nenhum componente especificado.
To detach the matrix attachment piece, press down on the attachment release button located at the top of the device.
Leaving your finger pressed down on the button, simply pull on the attachment to release it.
Using a JIS 1 screwdriver, unscrew seven 19mm outer screws located on the armature.
Using the same screwdriver, unscrew the 12mm outer screw located on the armature.
Gently pull up the motor and other components at the top of the device except the handle.
Uma outra pessoa concluiu este guia.
2 comentários
I have this tool and the attachments and I absolutely love it…but I'm pretty sure the gears are stripped…do you know anything about replacing those?
