Ir para o conteúdo principal
Black and Decker BDEDMT Motor Replacement
O que você precisa
  1. Black and Decker BDEDMT Motor Replacement, Detach Matrix Attachment: passo 1, imagem 1 %32 Black and Decker BDEDMT Motor Replacement, Detach Matrix Attachment: passo 1, imagem 2 %32
    • Remember to disconnect the device from all external power sources.
    • To detach the matrix attachment piece, press down on the attachment release button located at the top of the device.
    • Leaving your finger pressed down on the button, simply pull on the attachment to release it.
  2. Black and Decker BDEDMT Motor Replacement, Remove Mounting Hardware: passo 2, imagem 1 %32 Black and Decker BDEDMT Motor Replacement, Remove Mounting Hardware: passo 2, imagem 2 %32 Black and Decker BDEDMT Motor Replacement, Remove Mounting Hardware: passo 2, imagem 3 %32
    • Using a JIS 1 screwdriver, unscrew seven 19mm outer screws located on the armature.
    • Using the same screwdriver, unscrew the 12mm outer screw located on the armature.
  3. Black and Decker BDEDMT Motor Replacement, Motor: passo 3, imagem 1 %32
    • Gently pull up the motor and other components at the top of the device except the handle.
    • Watch out for the wires. They are connected to two compressed magnets in the black framework.
  4. Black and Decker BDEDMT Motor Replacement: passo 4, imagem 1 %32 Black and Decker BDEDMT Motor Replacement: passo 4, imagem 2 %32
    • Slide off the the black framework on the barring side.
    • You may have to compress the magnets in order to slide the framework off of the barring.
  5. Black and Decker BDEDMT Motor Replacement: passo 5, imagem 1 %32 Black and Decker BDEDMT Motor Replacement: passo 5, imagem 2 %32
    • Remove the release button attached at the front of the motor.
    • It may have already come off during Step 3.
  6. Black and Decker BDEDMT Motor Replacement: passo 6, imagem 1 %32 Black and Decker BDEDMT Motor Replacement: passo 6, imagem 2 %32
    • Work the silver magnetic ring off of the motor through the barring end.
    • The motor is now free.
Conclusão
Uma outra pessoa concluiu este guia.
Tyler Yurina
Membro desde: 02/01/16
407 Reputação
Autoria de 2 guias
Equipe
UW Tacoma, Team 1-2, Rose Winter 2016 Membro de UW Tacoma, Team 1-2, Rose Winter 2016
UWT-ROSE-W16S1G2
Membros da 4
Autoria de 11 guias
3 comentários
Hi,
Please can you tell me where to find the motor replacement part for this tool?
Thank you
Renato - Responder
I have this tool and the attachments and I absolutely love it…but I'm pretty sure the gears are stripped…do you know anything about replacing those?
cwilson0713@gmail.com - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 33
Duração total: 2,276
