Ir para o conteúdo principal
Black and Decker BDEDMT Circuit Board Replacement
O que você precisa
  1. Black and Decker BDEDMT Circuit Board Replacement, Detach Matrix Attachment: passo 1, imagem 1 %32 Black and Decker BDEDMT Circuit Board Replacement, Detach Matrix Attachment: passo 1, imagem 2 %32
    • Remember to disconnect the device from all external power sources.
    • To detach the matrix attachment piece, press down on the attachment release button located at the top of the device.
    • Leaving your finger pressed down on the button, simply pull on the attachment to release it.
  2. Black and Decker BDEDMT Circuit Board Replacement, Remove Mounting Hardware: passo 2, imagem 1 %32 Black and Decker BDEDMT Circuit Board Replacement, Remove Mounting Hardware: passo 2, imagem 2 %32 Black and Decker BDEDMT Circuit Board Replacement, Remove Mounting Hardware: passo 2, imagem 3 %32
    • Using a JIS 1 screwdriver, unscrew seven 19mm outer screws located on the armature.
    • Using the same screwdriver, unscrew the 12mm outer screw located on the armature.
  3. Black and Decker BDEDMT Circuit Board Replacement, Circuit Board: passo 3, imagem 1 %32 Black and Decker BDEDMT Circuit Board Replacement, Circuit Board: passo 3, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • There will be a white cord that runs from the power cord base to the circuit board located slightly above.
    • Use the tweezers to detach the entire white cord and blue connection piece as a whole from the circuit board.
  4. Black and Decker BDEDMT Circuit Board Replacement: passo 4, imagem 1 %32 Black and Decker BDEDMT Circuit Board Replacement: passo 4, imagem 2 %32 Black and Decker BDEDMT Circuit Board Replacement: passo 4, imagem 3 %32
    • There will be one black wire, a thin white wire and a thin red wire connecting to the trigger module from the circuit board. Using your needle nose tweezers insert one of the ends into the release slot below the white wire.
    • Make sure to aim the tweezers toward the wire.
    • Lift the end of the tweezers to release the wire.
    • The Circuit board is now free.
    • Do not force the removal of the wire.
    • Remember to reinsert the wires to their corresponding slots when reassembling.
Conclusão
Equipe
UW Tacoma, Team 1-2, Rose Winter 2016 Membro de UW Tacoma, Team 1-2, Rose Winter 2016
UWT-ROSE-W16S1G2
Membros da 4
Autoria de 11 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 29
Duração total: 799
